RECTIFIERs replaced with DIODEs
You are welcome. Two more to look over a Philco Model B956 (Riders 23) and Zenith Model T825F, G, andR Chassie 8T01 (Beitman 1955). I have both sets enjoyed fixing them both the Zenith was my first am/fm the Philco my 3rd am/fm set. Replaced the selenium with a in4007 in both and added app 50-100 ohm resistor sorry for not knowing the exact value I used. Reduce my line voltage to 105-110, mains run 119-124.8 from FPL. David
RECTIFIERs replaced with DIODEs - by Bradley Rush - 05-19-2014, 03:12 AM
RE: RECTIFIERs replaced with DIODEs - by morzh - 05-19-2014, 09:53 AM
RE: RECTIFIERs replaced with DIODEs - by tab10672 - 05-19-2014, 12:37 PM
RE: RECTIFIERs replaced with DIODEs - by tab10672 - 05-19-2014, 01:49 PM
RE: RECTIFIERs replaced with DIODEs - by morzh - 05-19-2014, 05:33 PM
RE: RECTIFIERs replaced with DIODEs - by Arran - 05-19-2014, 09:44 PM
RE: RECTIFIERs replaced with DIODEs - by codefox1 - 05-20-2014, 10:53 AM
RE: RECTIFIERs replaced with DIODEs - by K7Sparky - 05-21-2014, 06:48 PM
RE: RECTIFIERs replaced with DIODEs - by TV MAN - 05-24-2014, 11:25 AM
RE: RECTIFIERs replaced with DIODEs - by David - 05-25-2014, 03:47 PM
RE: RECTIFIERs replaced with DIODEs - by K7Sparky - 05-26-2014, 08:32 AM
RE: RECTIFIERs replaced with DIODEs - by David - 05-27-2014, 02:39 PM
There are currently 10409 online users. [Complete List]
» 4 Member(s) | 10405 Guest(s)
AvatarAvatarAvatarAvatar
