Free: 1942 issue of Service Magazine
Blacksmith, Thanks for making this magazine available. The article that really grabbed my attention was the one on phonograph motor repairs. I have three of them that need repair. Also love to see the adds. Since I was five years old at the time of this magazine I should have remembered everything that was in it but I was to busy playing with my cardboard war toys. Thanks again.
Dave D
Free: 1942 issue of Service Magazine - by Guest - 08-12-2008, 10:47 PM
[No subject] - by Ron Ramirez - 08-12-2008, 11:06 PM
[No subject] - by Dave D - 08-13-2008, 12:00 AM
[No subject] - by Texasrocker - 08-13-2008, 12:52 AM
There are currently 10483 online users. [Complete List]
» 2 Member(s) | 10481 Guest(s)
