shellac on dial cord to secure dial indicator/pointer?
While were sharing ideas on this subject, I have always used a small-dab of clear GE 100% silicone household glue applied with the tip of a toothpick. Can be removed easily also for re-positioning dial pointer if needed even after full dry if not too much is used. Silicone wont break down over time with moisture, heat/cold , etc. Flexible also.
[No subject] - by Guest - 08-12-2008, 12:48 PM
[No subject] - by exray - 08-12-2008, 08:48 PM
[No subject] - by Texasrocker - 08-13-2008, 12:30 AM
Philco 89 indicator light.
There are currently 3338 online users. [Complete List]
» 1 Member(s) | 3337 Guest(s)
