  • 1 Vote(s) - 1 Average
Philco 38-7 Radiobar Restoration
Thanks to all,
I appreciate all the great input. I have several restores going on right now and decided that the people here are the best on Philco radios. I have other models I'm working on but I will open up other threads as I run into questions.
73's
St Tee
Philco 38-7 Radiobar Restoration - by St Tee - 05-26-2014, 12:00 AM
RE: Philco 38-7 Radiobar Restoration - by Arran - 05-26-2014, 03:22 AM
RE: Philco 38-7 Radiobar Restoration - by St Tee - 05-26-2014, 12:04 PM
RE: Philco 38-7 Radiobar Restoration - by voroush - 05-26-2014, 05:26 PM
RE: Philco 38-7 Radiobar Restoration - by Arran - 05-26-2014, 09:44 PM
RE: Philco 38-7 Radiobar Restoration - by St Tee - 05-28-2014, 01:09 AM
RE: Philco 38-7 Radiobar Restoration - by Arran - 05-28-2014, 01:32 AM
RE: Philco 38-7 Radiobar Restoration - by St Tee - 05-28-2014, 04:49 PM
RE: Philco 38-7 Radiobar Restoration - by St Tee - 05-29-2014, 11:38 AM
RE: Philco 38-7 Radiobar Restoration - by Arran - 05-30-2014, 01:34 AM
RE: Philco 38-7 Radiobar Restoration - by St Tee - 06-07-2014, 03:05 PM
RE: Philco 38-7 Radiobar Restoration - by morzh - 06-07-2014, 09:17 PM
RE: Philco 38-7 Radiobar Restoration - by Arran - 06-07-2014, 09:51 PM
RE: Philco 38-7 Radiobar Restoration - by morzh - 06-07-2014, 10:15 PM
There are currently 6507 online users. [Complete List]
» 2 Member(s) | 6505 Guest(s)
