Record player side sound degrades after warmup
Hey guys - It's a Philco M-1666-124. I believe it's tubes in there. The copyright date from the manual is from 1963.
RE: Record player side sound degrades after warmup - by raywoc - 05-28-2014, 08:22 PM
There are currently 3755 online users. [Complete List]
» 1 Member(s) | 3754 Guest(s)
