Stewart Warner alignment issues
Morzh
I think I have another 6A8 and will try it in the morning, The print lists the 6H6 for the AVC but the socket voltages are 0 except for the heater. What pins should I check and what voltages should I see?
Stewart Warner alignment issues - by Eric - 05-29-2014, 01:12 PM
RE: Stewart Warner alignment issues - by morzh - 05-29-2014, 01:25 PM
RE: Stewart Warner alignment issues - by Eric - 05-29-2014, 07:38 PM
RE: Stewart Warner alignment issues - by morzh - 05-29-2014, 07:55 PM
RE: Stewart Warner alignment issues - by Eric - 05-30-2014, 04:32 PM
RE: Stewart Warner alignment issues - by morzh - 05-30-2014, 07:06 PM
RE: Stewart Warner alignment issues - by Eric - 05-31-2014, 09:24 AM
RE: Stewart Warner alignment issues - by Eric - 06-01-2014, 09:15 AM
RE: Stewart Warner alignment issues - by morzh - 06-01-2014, 08:56 PM
RE: Stewart Warner alignment issues - by Eric - 06-02-2014, 03:14 PM
RE: Stewart Warner alignment issues - by morzh - 06-02-2014, 03:36 PM
RE: Stewart Warner alignment issues - by Eric - 06-02-2014, 04:07 PM
RE: Stewart Warner alignment issues - by morzh - 06-02-2014, 04:54 PM
RE: Stewart Warner alignment issues - by Eric - 06-02-2014, 05:04 PM
RE: Stewart Warner alignment issues - by morzh - 06-02-2014, 05:17 PM
RE: Stewart Warner alignment issues - by Eric - 06-02-2014, 05:24 PM
RE: Stewart Warner alignment issues - by Eric - 06-03-2014, 05:22 PM
RE: Stewart Warner alignment issues - by morzh - 06-03-2014, 05:25 PM
RE: Stewart Warner alignment issues - by Mondial - 06-03-2014, 06:30 PM
RE: Stewart Warner alignment issues - by Eric - 06-04-2014, 11:48 AM
RE: Stewart Warner alignment issues - by Eric - 06-11-2014, 03:12 PM
RE: Stewart Warner alignment issues - by morzh - 06-11-2014, 03:38 PM
RE: Stewart Warner alignment issues - by Mondial - 06-11-2014, 04:19 PM
RE: Stewart Warner alignment issues - by Eric - 06-11-2014, 05:15 PM
RE: Stewart Warner alignment issues - by morzh - 06-11-2014, 09:15 PM
RE: Stewart Warner alignment issues - by AI2V - 06-12-2014, 05:11 PM
RE: Stewart Warner alignment issues - by Eric - 06-14-2014, 07:34 PM
There are currently 3424 online users. [Complete List]
» 1 Member(s) | 3423 Guest(s)
