49-501 question
Here is more info on the special cap. http://www.antiqueradios.com/forums/view...c6e9960d4b
I would just replace it with a regular cap as Chuck S states.
Should be a .2 MF by looking at the schematic here.
http://www.nostalgiaair.org/Resources/659/M0013659.htm
On the 16B hopefully someone will reply that has seen this problem before as I have not.
BTW all topic reply emails will come from Ron no matter who replies.
Sorry I'm not Ron.
Bill
It's not what you don't know that hurts you it's what you know that's not so.
49-501 question - by tubenutt - 08-13-2008, 10:45 PM
[No subject] - by wonderwrench - 08-13-2008, 11:07 PM
[No subject] - by tubenutt - 08-14-2008, 02:53 AM
[No subject] - by wonderwrench - 08-14-2008, 11:41 AM
[No subject] - by tubenutt - 08-14-2008, 12:10 PM
The speaker table error?
Philco 70 antenna lead
There are currently 3366 online users. [Complete List]
» 1 Member(s) | 3365 Guest(s)
