philco 90 -just restored but system hums
I don't have an 84B and have never listened to one but I would think the 90 should be a much better radio. I know my 90 works great and gets some really distant stations with ease.
Gregb
RE: philco 90 -just restored but system hums - by gregb - 05-30-2014, 09:52 PM
