Model 38 Power supply
many years ago I looked at spice to do software simulation of circuit behavior . It 's a bit of overkill for this but there is open source software available that can model a circuit to see what components would work. It just might be a fun experiment. I am 25 years removed from this work but it's good to get back into the flow. BTW, the circuit I saw some time ago belonged to Ron, so it went beyond the napkin note phase as it was online somewhere.
Model 38 Power supply - by St Tee - 05-29-2014, 01:36 PM
RE: Model 38 Power supply - by morzh - 05-29-2014, 05:29 PM
RE: Model 38 Power supply - by David - 05-29-2014, 07:17 PM
RE: Model 38 Power supply - by David - 05-29-2014, 07:20 PM
RE: Model 38 Power supply - by Arran - 05-30-2014, 01:23 AM
RE: Model 38 Power supply - by David - 05-30-2014, 12:45 PM
RE: Model 38 Power supply - by Ron Ramirez - 05-30-2014, 01:01 PM
RE: Model 38 Power supply - by St Tee - 05-30-2014, 10:58 PM
RE: Model 38 Power supply - by morzh - 05-30-2014, 11:04 PM
RE: Model 38 Power supply - by Ron Ramirez - 05-30-2014, 11:19 PM
RE: Model 38 Power supply - by St Tee - 05-31-2014, 12:01 AM
RE: Model 38 Power supply - by St Tee - 05-31-2014, 12:10 AM
There are currently 7269 online users. [Complete List]
» 1 Member(s) | 7268 Guest(s)
