Model 38 Power supply
St Tee Wrote:BTW, the circuit I saw some time ago belonged to Ron, so it went beyond the napkin note phase as it was online somewhere.
Yes, you did see it - and it was right here in the Phorum!
http://philcoradio.com/phorum/showthread.php?tid=469
(I had to do a Google search to find this. B-B-B-Bing didn't bring it up.)
Model 38 Power supply - by St Tee - 05-29-2014, 01:36 PM
RE: Model 38 Power supply - by morzh - 05-29-2014, 05:29 PM
RE: Model 38 Power supply - by David - 05-29-2014, 07:17 PM
RE: Model 38 Power supply - by David - 05-29-2014, 07:20 PM
RE: Model 38 Power supply - by Arran - 05-30-2014, 01:23 AM
RE: Model 38 Power supply - by David - 05-30-2014, 12:45 PM
RE: Model 38 Power supply - by Ron Ramirez - 05-30-2014, 01:01 PM
RE: Model 38 Power supply - by St Tee - 05-30-2014, 10:58 PM
RE: Model 38 Power supply - by morzh - 05-30-2014, 11:04 PM
RE: Model 38 Power supply - by Ron Ramirez - 05-30-2014, 11:19 PM
RE: Model 38 Power supply - by St Tee - 05-31-2014, 12:01 AM
RE: Model 38 Power supply - by St Tee - 05-31-2014, 12:10 AM
There are currently 7048 online users. [Complete List]
» 1 Member(s) | 7047 Guest(s)
