Battery pack P-60D11L
P-60D11L would like to know it's pin out
Yellow A+ = +1.5Vdc
Red B+ = 90Vdc
White B- = -90Vdc
Checking the tubes in the 41-90 Philco I have come up with the above pin out. 1A7, 1N5, 1H5, 1A5
Does this seem correct?
Battery pack P-60D11L - by Bradley Rush - 05-31-2014, 03:56 PM
There are currently 10595 online users. [Complete List]
» 4 Member(s) | 10591 Guest(s)
AvatarAvatarAvatarAvatar
