  • 1 Vote(s) - 5 Average
111 grillcloth cardboard frame.
If the board material is too far gone, you might want to look at some MDF panel material at Lowe's or Home Depot or your local lumberyard. I had to use some MDF material to replace a crumbling grill cloth backing board on my 40-201. It worked well and was about the same thickness and the original material.
Joe
111 grillcloth cardboard frame. - by morzh - 05-11-2014, 09:12 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 01:35 AM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 10:15 AM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 11:01 AM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 12:11 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 02:50 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 03:10 PM
RE: 111 grillcloth cardboard frame. - by codefox1 - 05-12-2014, 03:23 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 04:21 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 05:06 PM
RE: 111 grillcloth cardboard frame. - by Jamie - 05-12-2014, 05:19 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 11:23 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 11:37 PM
RE: 111 grillcloth cardboard frame. - by sam - 05-13-2014, 12:49 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-13-2014, 03:02 PM
RE: 111 grillcloth cardboard frame. - by Jamie - 05-13-2014, 07:07 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-13-2014, 08:20 PM
RE: 111 grillcloth cardboard frame. - by Joeztech - 06-01-2014, 09:48 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-01-2014, 09:52 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-02-2014, 02:09 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-02-2014, 03:33 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-02-2014, 03:47 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-02-2014, 11:22 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-03-2014, 08:56 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-07-2014, 08:34 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-07-2014, 10:36 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-08-2014, 12:17 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-08-2014, 12:38 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-18-2014, 10:37 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-18-2014, 09:00 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-18-2014, 09:09 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-18-2014, 11:14 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-19-2014, 07:27 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-19-2014, 09:37 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-19-2014, 03:18 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-19-2014, 05:36 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-20-2014, 11:49 AM
