Stewart Warner alignment issues
So if it were brown, brown, brown that would be 110?
It shows .010n holding the leads so the cap is really about 17pf and ok
Stewart Warner alignment issues - by Eric - 05-29-2014, 01:12 PM
RE: Stewart Warner alignment issues - by morzh - 05-29-2014, 01:25 PM
RE: Stewart Warner alignment issues - by Eric - 05-29-2014, 07:38 PM
RE: Stewart Warner alignment issues - by morzh - 05-29-2014, 07:55 PM
RE: Stewart Warner alignment issues - by Eric - 05-30-2014, 04:32 PM
RE: Stewart Warner alignment issues - by morzh - 05-30-2014, 07:06 PM
RE: Stewart Warner alignment issues - by Eric - 05-31-2014, 09:24 AM
RE: Stewart Warner alignment issues - by Eric - 06-01-2014, 09:15 AM
RE: Stewart Warner alignment issues - by morzh - 06-01-2014, 08:56 PM
RE: Stewart Warner alignment issues - by Eric - 06-02-2014, 03:14 PM
RE: Stewart Warner alignment issues - by morzh - 06-02-2014, 03:36 PM
RE: Stewart Warner alignment issues - by Eric - 06-02-2014, 04:07 PM
RE: Stewart Warner alignment issues - by morzh - 06-02-2014, 04:54 PM
RE: Stewart Warner alignment issues - by Eric - 06-02-2014, 05:04 PM
RE: Stewart Warner alignment issues - by morzh - 06-02-2014, 05:17 PM
RE: Stewart Warner alignment issues - by Eric - 06-02-2014, 05:24 PM
RE: Stewart Warner alignment issues - by Eric - 06-03-2014, 05:22 PM
RE: Stewart Warner alignment issues - by morzh - 06-03-2014, 05:25 PM
RE: Stewart Warner alignment issues - by Mondial - 06-03-2014, 06:30 PM
RE: Stewart Warner alignment issues - by Eric - 06-04-2014, 11:48 AM
RE: Stewart Warner alignment issues - by Eric - 06-11-2014, 03:12 PM
RE: Stewart Warner alignment issues - by morzh - 06-11-2014, 03:38 PM
RE: Stewart Warner alignment issues - by Mondial - 06-11-2014, 04:19 PM
RE: Stewart Warner alignment issues - by Eric - 06-11-2014, 05:15 PM
RE: Stewart Warner alignment issues - by morzh - 06-11-2014, 09:15 PM
RE: Stewart Warner alignment issues - by AI2V - 06-12-2014, 05:11 PM
RE: Stewart Warner alignment issues - by Eric - 06-14-2014, 07:34 PM
