  • 1 Vote(s) - 5 Average
Philco 89/19
I need a favor.
I am starting chassis work on this 89/19. I do not own Riders Vol. 3 which has the correct chassis schematic...I think. The Nostalgia Air printout is so small and so fuzzy (even an enlarged PDF image) that I cannot read some of the values for the resistors and caps which are listed on the left-hand side of "Philco page 3-33" in Vol. 3.
Can someone with a clear copy tell me the correct numbers, both the circled numbers and the values? Or maybe email a scan of your original?
I'd sure appreciate . Thanks.
Art
Philco 89/19 - by Art Hoch - 05-30-2014, 10:52 AM
RE: Philco 89/19 - by Ron Ramirez - 05-30-2014, 12:58 PM
RE: Philco 89/19 - by exray - 05-31-2014, 05:18 AM
RE: Philco 89/19 - by morzh - 05-31-2014, 10:51 AM
RE: Philco 89/19 - by PAradiogeek - 05-31-2014, 03:54 PM
RE: Philco 89/19 - by Art Hoch - 06-02-2014, 09:47 PM
RE: Philco 89/19 - by gregb - 06-02-2014, 11:05 PM
RE: Philco 89/19 - by PAradiogeek - 06-03-2014, 12:42 AM
RE: Philco 89/19 - by Art Hoch - 06-03-2014, 02:16 PM
RE: Philco 89/19 - by gregb - 06-03-2014, 02:28 PM
RE: Philco 89/19 - by Chuck Schwark - 06-03-2014, 03:10 PM
RE: Philco 89/19 - by Art Hoch - 06-05-2014, 09:32 PM
RE: Philco 89/19 - by Art Hoch - 06-26-2014, 03:55 PM
RE: Philco 89/19 - by Art Hoch - 07-02-2014, 10:49 PM
RE: Philco 89/19 - by PAradiogeek - 07-06-2014, 03:21 PM
RE: Philco 89/19 - by Art Hoch - 07-09-2014, 06:00 PM
RE: Philco 89/19 - by Randy H. - 07-12-2014, 06:14 PM
RE: Philco 89/19 - by Art Hoch - 07-12-2014, 08:57 PM
RE: Philco 89/19 - by Art Hoch - 07-14-2014, 10:44 AM
RE: Philco 89/19 - by Ron Ramirez - 07-14-2014, 10:45 AM
RE: Philco 89/19 - by Art Hoch - 07-14-2014, 08:19 PM
RE: Philco 89/19 - by Art Hoch - 07-23-2014, 12:24 PM
RE: Philco 89/19 - by Ron Ramirez - 07-23-2014, 12:36 PM
There are currently 8532 online users. [Complete List]
» 1 Member(s) | 8531 Guest(s)
