Atwater Kent 84
Started working today on the set.Great workmanship, weird coils and strange resistors. Does anyone know how to read the value of those? Tried to compare the known values of certain resistors with their markings - makes no sense at all. Nostalgia Air has limited info and alignment procedure is missing.Hope after recapping it will come to life.
Atwater Kent 84 - by fields 100 - 06-02-2014, 10:49 PM
RE: Atwater Kent 84 - by Carl Travis - 06-02-2014, 11:32 PM
There are currently 4942 online users. [Complete List]
» 2 Member(s) | 4940 Guest(s)
