  • 1 Vote(s) - 5 Average
111 grillcloth cardboard frame.
I would say the main reason they are there would be just to help keep the shape of the cloth. Without it, the cloth would stretch easier and wouldn't be as taught after some time. Just a little bit of backing to keep its shape longer. Surprising what just a little will do to help keep its shape. Is it probably broken some from being bumped again and again over the years.
111 grillcloth cardboard frame. - by morzh - 05-11-2014, 09:12 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 01:35 AM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 10:15 AM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 11:01 AM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 12:11 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 02:50 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 03:10 PM
RE: 111 grillcloth cardboard frame. - by codefox1 - 05-12-2014, 03:23 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 04:21 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 05:06 PM
RE: 111 grillcloth cardboard frame. - by Jamie - 05-12-2014, 05:19 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 11:23 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 11:37 PM
RE: 111 grillcloth cardboard frame. - by sam - 05-13-2014, 12:49 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-13-2014, 03:02 PM
RE: 111 grillcloth cardboard frame. - by Jamie - 05-13-2014, 07:07 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-13-2014, 08:20 PM
RE: 111 grillcloth cardboard frame. - by Joeztech - 06-01-2014, 09:48 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-01-2014, 09:52 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-02-2014, 02:09 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-02-2014, 03:33 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-02-2014, 03:47 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-02-2014, 11:22 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-03-2014, 08:56 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-07-2014, 08:34 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-07-2014, 10:36 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-08-2014, 12:17 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-08-2014, 12:38 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-18-2014, 10:37 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-18-2014, 09:00 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-18-2014, 09:09 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-18-2014, 11:14 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-19-2014, 07:27 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-19-2014, 09:37 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-19-2014, 03:18 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-19-2014, 05:36 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-20-2014, 11:49 AM
