Model 84, code 121 question(s)
It looks to me like it should be twisted around the lead to the volume control pot. Look at number 3 on the parts list, it says, "capacity obtained by twisting two leads together".
M R Radios   C M Tubes
RE: Model 84, code 121 question(s) - by morzh - 06-03-2014, 08:47 PM
RE: Model 84, code 121 question(s) - by morzh - 06-03-2014, 10:05 PM
RE: Model 84, code 121 question(s) - by morzh - 06-04-2014, 08:58 AM
RE: Model 84, code 121 question(s) - by Steve Davis - 06-04-2014, 11:57 AM
RE: Model 84, code 121 question(s) - by morzh - 06-04-2014, 01:33 PM
There are currently 3636 online users. [Complete List]
» 1 Member(s) | 3635 Guest(s)
