Help with Identification.
I saw this one on K-town show.
I remember commenting that it looked a whole lot like the Philco 20 (latticework is different but the shape and the spiral grove ornament are similar).
Is it a Gloritone by chance?
Or it could be a Zenette.
http://www.radioatticarchives.com/radio.htm?radio=6153
http://www.tuberadioland.com/zenithL_main.html
Help with Identification. - by radiohenry - 06-05-2014, 04:41 PM
RE: Help with Identification. - by OldRestorer - 06-05-2014, 05:14 PM
RE: Help with Identification. - by morzh - 06-05-2014, 05:36 PM
RE: Help with Identification. - by radiohenry - 06-05-2014, 07:35 PM
RE: Help with Identification. - by morzh - 06-05-2014, 07:48 PM
RE: Help with Identification. - by Eliot Ness - 06-05-2014, 08:54 PM
RE: Help with Identification. - by radiohenry - 06-06-2014, 06:47 PM
There are currently 6055 online users. [Complete List]
» 3 Member(s) | 6052 Guest(s)
