Help with Identification.
I regret now I did not remember the brand, it had exact same front as yours.
As for repairs, this is likely a TRF and a common sense recap/recarb will probably do it, and alignment should be simple as if it is a TRF there is no heterodyne alignment song and dance. Even with no sch this should be no too bad.
Help with Identification. - by radiohenry - 06-05-2014, 04:41 PM
RE: Help with Identification. - by OldRestorer - 06-05-2014, 05:14 PM
RE: Help with Identification. - by morzh - 06-05-2014, 05:36 PM
RE: Help with Identification. - by radiohenry - 06-05-2014, 07:35 PM
RE: Help with Identification. - by morzh - 06-05-2014, 07:48 PM
RE: Help with Identification. - by Eliot Ness - 06-05-2014, 08:54 PM
RE: Help with Identification. - by radiohenry - 06-06-2014, 06:47 PM
There are currently 5887 online users. [Complete List]
» 1 Member(s) | 5886 Guest(s)
