39-7 restore
Already done...
I did an oops on the length of shrink tubing on one of the white wires and I ended up using brown over the black wire because well.. I'm out. Icon_smile
side note: has anyone ever thinned liquid tape? my black is so thick and chunky. noted the main ingredient is naptha, a shot of ronsonol?
[Image: http://www.philcoradio.com/images/phorum...7f4e64.jpg]
[Image: http://www.philcoradio.com/images/phorum...be3e6d.jpg]
39-7 restore - by bfrohwein - 06-02-2014, 12:20 PM
RE: 39-7 restore - by bfrohwein - 06-02-2014, 06:56 PM
RE: 39-7 restore - by bfrohwein - 06-05-2014, 01:27 AM
RE: 39-7 restore - by Eliot Ness - 06-05-2014, 07:46 AM
RE: 39-7 restore - by bfrohwein - 06-05-2014, 10:16 AM
RE: 39-7 restore - by morzh - 06-05-2014, 10:40 AM
RE: 39-7 restore - by Nick3092 - 06-05-2014, 11:58 PM
RE: 39-7 restore - by Arran - 06-06-2014, 12:22 AM
RE: 39-7 restore - by bfrohwein - 06-06-2014, 04:10 PM
RE: 39-7 restore - by David - 06-07-2014, 03:31 PM
RE: 39-7 restore - by bfrohwein - 06-07-2014, 04:02 PM
RE: 39-7 restore - by Ron Ramirez - 06-07-2014, 10:42 PM
RE: 39-7 restore - by bfrohwein - 06-20-2014, 12:40 AM
There are currently 10203 online users. [Complete List]
» 1 Member(s) | 10202 Guest(s)
