tube tester data for a few oddball tubes
Go here and then select Hickok for all kinds of downloads and things.
http://padgett.performanceresearch.us/
RE: tube tester data for a few oddball tubes - by codefox1 - 06-07-2014, 04:23 PM
There are currently 10206 online users. [Complete List]
» 3 Member(s) | 10203 Guest(s)
