tube tester data for a few oddball tubes
I don't know what number chart you have but here's part of a Hickok bulletin that may help.
[Image: http://i863.photobucket.com/albums/ab191...g~original]
Larry
RE: tube tester data for a few oddball tubes - by rocketeer - 06-07-2014, 06:34 PM
There are currently 10221 online users. [Complete List]
» 2 Member(s) | 10219 Guest(s)
