39-7 restore
Looking at the two schematics, yes, it appears that you can use a 40-125 pushbutton assembly in a 39-7. They have different part numbers but the schematic drawings of each look the same.
39-7 restore - by bfrohwein - 06-02-2014, 12:20 PM
RE: 39-7 restore - by bfrohwein - 06-02-2014, 06:56 PM
RE: 39-7 restore - by bfrohwein - 06-05-2014, 01:27 AM
RE: 39-7 restore - by Eliot Ness - 06-05-2014, 07:46 AM
RE: 39-7 restore - by bfrohwein - 06-05-2014, 10:16 AM
RE: 39-7 restore - by morzh - 06-05-2014, 10:40 AM
RE: 39-7 restore - by Nick3092 - 06-05-2014, 11:58 PM
RE: 39-7 restore - by Arran - 06-06-2014, 12:22 AM
RE: 39-7 restore - by bfrohwein - 06-06-2014, 04:10 PM
RE: 39-7 restore - by David - 06-07-2014, 03:31 PM
RE: 39-7 restore - by bfrohwein - 06-07-2014, 04:02 PM
RE: 39-7 restore - by Ron Ramirez - 06-07-2014, 10:42 PM
RE: 39-7 restore - by bfrohwein - 06-20-2014, 12:40 AM
There are currently 10419 online users. [Complete List]
» 2 Member(s) | 10417 Guest(s)
