Philco 90 Audio Transformer
http://www.nostalgiaair.org/PagesByModel...013838.pdf
http://philcoradio.com/tech/images/77.jpg
These sch are of 77 and show centertapped xfmr.
Philco 90 Audio Transformer - by nuke - 05-12-2014, 09:47 PM
RE: Philco 90 Audio Transformer - by morzh - 05-12-2014, 11:19 PM
RE: Philco 90 Audio Transformer - by nuke - 05-15-2014, 09:10 AM
RE: Philco 90 Audio Transformer - by morzh - 05-15-2014, 09:59 AM
RE: Philco 90 Audio Transformer - by Ron Ramirez - 05-15-2014, 10:35 AM
RE: Philco 90 Audio Transformer - by nuke - 05-15-2014, 11:08 AM
RE: Philco 90 Audio Transformer - by morzh - 05-15-2014, 12:13 PM
RE: Philco 90 Audio Transformer - by nuke - 06-08-2014, 07:31 PM
RE: Philco 90 Audio Transformer - by morzh - 06-08-2014, 08:07 PM
RE: Philco 90 Audio Transformer - by nuke - 06-08-2014, 09:21 PM
RE: Philco 90 Audio Transformer - by morzh - 06-08-2014, 10:07 PM
RE: Philco 90 Audio Transformer - by nuke - 06-11-2014, 10:38 PM
RE: Philco 90 Audio Transformer - by nuke - 07-01-2014, 10:15 PM
RE: Philco 90 Audio Transformer - by Arran - 07-01-2014, 11:02 PM
RE: Philco 90 Audio Transformer - by nuke - 07-01-2014, 11:05 PM
There are currently 10085 online users. [Complete List]
» 1 Member(s) | 10084 Guest(s)
