Issue and question on toner
It is nearly impossible to spot or blend toner. I know this is not what you want to hear, but I think you will need to sand the toner off and try again. I have had to do it a few times.
M R Radios   C M Tubes
Issue and question on toner - by TheBakery - 06-09-2014, 07:42 AM
RE: Issue and question on toner - by OldRestorer - 06-09-2014, 07:59 AM
RE: Issue and question on toner - by Steve Davis - 06-09-2014, 08:21 AM
RE: Issue and question on toner - by TheBakery - 06-09-2014, 09:57 AM
RE: Issue and question on toner - by Warren - 06-09-2014, 01:41 PM
RE: Issue and question on toner - by bfrohwein - 06-09-2014, 02:59 PM
RE: Issue and question on toner - by Phlogiston - 06-09-2014, 05:33 PM
RE: Issue and question on toner - by TA Forbes - 06-10-2014, 10:01 AM
There are currently 10171 online users. [Complete List]
» 1 Member(s) | 10170 Guest(s)
