philco bakelite blocks
Regular film caps can fail SHORTED, that's why X/Y caps are safety types - they fail OPEN. On the A/C line bypasses, X/Y's are safer.
philco bakelite blocks - by Chris Drumma - 12-04-2005, 03:40 PM
[No subject] - by Chuck Schwark - 12-04-2005, 03:54 PM
[No subject] - by Chris Drumma - 12-04-2005, 04:24 PM
[No subject] - by Ron Ramirez - 12-04-2005, 05:05 PM
[No subject] - by Poston Drake - 12-07-2005, 01:26 PM
[No subject] - by don'tdomelikethat - 12-07-2005, 07:15 PM
[No subject] - by Guest - 12-08-2005, 10:14 PM
[No subject] - by Ron Ramirez - 12-08-2005, 10:44 PM
[No subject] - by Chuck Schwark - 12-09-2005, 12:32 AM
[No subject] - by Ron Ramirez - 12-09-2005, 01:42 AM
[No subject] - by Poston Drake - 12-09-2005, 11:19 AM
[No subject] - by Ron Ramirez - 12-09-2005, 12:52 PM
There are currently 4613 online users. [Complete List]
» 1 Member(s) | 4612 Guest(s)
