Philco 41-kr restoration
That's all I use to get paint off, paint and varnish remover, though sometimes it's difficult getting baked on enamel paint off of a Bakelite radio from the 1950s. With regard to the grain sometimes you run into a nice grain even in junk wood like poplar, if that's what they used, I doubt whether they would have wasted something like walnut on a cabinet they intended to paint but you never know. I would have thought that they would stick to a species of wood that is easy to cut and shape, maybe it's alder? I would be tempted to refinish it without the paint, even though it is not original, you can always paint over it at a later date.
Philco 41-kr restoration - by OldRestorer - 06-07-2014, 06:32 PM
RE: Philco 41-kr restoration - by OldRestorer - 06-07-2014, 06:33 PM
RE: Philco 41-kr restoration - by morzh - 06-07-2014, 08:05 PM
RE: Philco 41-kr restoration - by Ron Ramirez - 06-08-2014, 08:27 AM
RE: Philco 41-kr restoration - by OldRestorer - 06-08-2014, 08:45 AM
RE: Philco 41-kr restoration - by morzh - 06-08-2014, 12:35 PM
RE: Philco 41-kr restoration - by Ron Ramirez - 06-09-2014, 08:22 PM
RE: Philco 41-kr restoration - by Arran - 06-09-2014, 11:36 PM
RE: Philco 41-kr restoration - by OldRestorer - 06-10-2014, 07:47 AM
RE: Philco 41-kr restoration - by tab10672 - 06-10-2014, 11:12 AM
RE: Philco 41-kr restoration - by OldRestorer - 06-10-2014, 11:57 AM
RE: Philco 41-kr restoration - by tab10672 - 06-10-2014, 12:06 PM
RE: Philco 41-kr restoration - by Ron Ramirez - 06-10-2014, 12:50 PM
RE: Philco 41-kr restoration - by tab10672 - 06-10-2014, 01:05 PM
RE: Philco 41-kr restoration - by TA Forbes - 06-10-2014, 09:06 PM
RE: Philco 41-kr restoration - by rocklandman - 06-11-2014, 09:56 PM
RE: Philco 41-kr restoration - by OldRestorer - 06-12-2014, 07:20 AM
RE: Philco 41-kr restoration - by morzh - 06-12-2014, 09:53 AM
RE: Philco 41-kr restoration - by klondike98 - 06-12-2014, 05:06 PM
RE: Philco 41-kr restoration - by OldRestorer - 06-12-2014, 07:05 PM
RE: Philco 41-kr restoration - by Arran - 06-12-2014, 07:13 PM
RE: Philco 41-kr restoration - by morzh - 06-12-2014, 07:25 PM
RE: Philco 41-kr restoration - by klondike98 - 06-12-2014, 09:19 PM
RE: Philco 41-kr restoration - by OldRestorer - 06-12-2014, 09:46 PM
RE: Philco 41-kr restoration - by Arran - 06-12-2014, 09:54 PM
RE: Philco 41-kr restoration - by morzh - 06-12-2014, 10:24 PM
RE: Philco 41-kr restoration - by OldRestorer - 06-13-2014, 07:36 AM
RE: Philco 41-kr restoration - by morzh - 06-13-2014, 09:16 AM
RE: Philco 41-kr restoration - by Arran - 06-13-2014, 07:58 PM
RE: Philco 41-kr restoration - by morzh - 06-13-2014, 09:11 PM
RE: Philco 41-kr restoration - by klondike98 - 06-21-2014, 09:08 PM
RE: Philco 41-kr restoration - by OldRestorer - 06-22-2014, 10:28 AM
RE: Philco 41-kr restoration - by morzh - 06-22-2014, 10:58 AM
RE: Philco 41-kr restoration - by OldRestorer - 06-22-2014, 11:32 AM
RE: Philco 41-kr restoration - by morzh - 06-22-2014, 09:01 PM
RE: Philco 41-kr restoration - by OldRestorer - 06-23-2014, 07:08 AM
RE: Philco 41-kr restoration - by morzh - 06-23-2014, 12:05 PM
RE: Philco 41-kr restoration - by sam - 06-23-2014, 12:49 PM
RE: Philco 41-kr restoration - by morzh - 06-23-2014, 03:38 PM
RE: Philco 41-kr restoration - by Eliot Ness - 06-23-2014, 07:34 PM
RE: Philco 41-kr restoration - by morzh - 06-23-2014, 07:40 PM
RE: Philco 41-kr restoration - by Arran - 06-23-2014, 11:10 PM
RE: Philco 41-kr restoration - by morzh - 06-24-2014, 08:41 AM
RE: Philco 41-kr restoration - by OldRestorer - 07-04-2014, 01:09 PM
RE: Philco 41-kr restoration - by tab10672 - 07-04-2014, 06:51 PM
RE: Philco 41-kr restoration - by OldRestorer - 08-10-2014, 09:09 PM
RE: Philco 41-kr restoration - by sam - 08-10-2014, 09:55 PM
RE: Philco 41-kr restoration - by OldRestorer - 08-10-2014, 10:16 PM
RE: Philco 41-kr restoration - by morzh - 08-10-2014, 10:22 PM
RE: Philco 41-kr restoration - by OldRestorer - 08-14-2014, 11:23 AM
RE: Philco 41-kr restoration - by sam - 08-14-2014, 12:39 PM
RE: Philco 41-kr restoration - by OldRestorer - 08-14-2014, 01:07 PM
RE: Philco 41-kr restoration - by morzh - 08-14-2014, 01:33 PM
RE: Philco 41-kr restoration - by OldRestorer - 08-15-2014, 09:00 AM
RE: Philco 41-kr restoration - by OldRestorer - 08-16-2014, 10:11 AM
RE: Philco 41-kr restoration - by tab10672 - 08-16-2014, 01:39 PM
RE: Philco 41-kr restoration - by sam - 08-16-2014, 01:51 PM
RE: Philco 41-kr restoration - by OldRestorer - 08-16-2014, 02:44 PM
RE: Philco 41-kr restoration - by tab10672 - 08-16-2014, 04:31 PM
There are currently 10786 online users. [Complete List]
» 3 Member(s) | 10783 Guest(s)
