An Idea Realized - The Philco Super 89
Ron, when I did the restoration on my model 19, I did have to rewind the feed back winding of the oscillator coil as is usually the case. I also baked it in the oven and sprayed it with lacquer and I have never had any trouble with the oscillator. But I am going to do the modification to improve the reliability (and hopefully the performance) of the radio. As far as authenticity, it doesn't matter because my radio isn't a perfect example anyway. Also Ron I would like to say thank you for putting this type of information out for the rest of us.
M R Radios   C M Tubes
[No subject] - by Steve Davis - 08-17-2008, 05:58 PM
[No subject] - by Ron Ramirez - 08-20-2008, 10:49 PM
[No subject] - by Ron Ramirez - 08-20-2008, 11:03 PM
[No subject] - by BDM - 08-21-2008, 12:28 AM
[No subject] - by Ron Ramirez - 08-21-2008, 06:30 PM
Philco Super 89 completed! - by Ron Ramirez - 09-29-2008, 10:18 PM
Eico 232 VTVM Schematic
There are currently 9850 online users. [Complete List]
» 1 Member(s) | 9849 Guest(s)
