  • 1 Vote(s) - 5 Average
Kirk's PT69
Kirk, you ought to see about getting your model 16X working properly. They are a very good radio!!!
Kirk's PT69 - by morzh - 05-20-2014, 08:04 AM
RE: Kirk's PT69 - by PAradiogeek - 05-20-2014, 12:02 PM
RE: Kirk's PT69 - by Jamie - 05-20-2014, 12:13 PM
RE: Kirk's PT69 - by morzh - 05-20-2014, 01:23 PM
RE: Kirk's PT69 - by morzh - 05-20-2014, 11:09 PM
RE: Kirk's PT69 - by morzh - 05-22-2014, 09:35 PM
RE: Kirk's PT69 - by OldRestorer - 05-22-2014, 10:01 PM
RE: Kirk's PT69 - by morzh - 05-22-2014, 10:12 PM
RE: Kirk's PT69 - by Arran - 05-22-2014, 10:19 PM
RE: Kirk's PT69 - by morzh - 05-22-2014, 10:28 PM
RE: Kirk's PT69 - by morzh - 05-22-2014, 10:31 PM
RE: Kirk's PT69 - by OldRestorer - 05-23-2014, 07:48 AM
RE: Kirk's PT69 - by morzh - 05-23-2014, 08:13 AM
RE: Kirk's PT69 - by Arran - 05-24-2014, 02:48 AM
RE: Kirk's PT69 - by morzh - 05-24-2014, 03:12 PM
RE: Kirk's PT69 - by Arran - 05-25-2014, 01:11 AM
RE: Kirk's PT69 - by morzh - 05-25-2014, 06:19 PM
RE: Kirk's PT69 - by morzh - 06-09-2014, 09:01 PM
RE: Kirk's PT69 - by OldRestorer - 06-10-2014, 07:40 AM
RE: Kirk's PT69 - by TA Forbes - 06-10-2014, 09:57 AM
RE: Kirk's PT69 - by morzh - 06-10-2014, 10:43 AM
RE: Kirk's PT69 - by OldRestorer - 06-10-2014, 10:45 AM
RE: Kirk's PT69 - by morzh - 06-10-2014, 10:54 AM
RE: Kirk's PT69 - by OldRestorer - 06-10-2014, 11:53 AM
RE: Kirk's PT69 - by morzh - 06-10-2014, 01:46 PM
RE: Kirk's PT69 - by morzh - 06-12-2014, 10:09 PM
RE: Kirk's PT69 - by OldRestorer - 06-13-2014, 07:38 AM
There are currently 10472 online users. [Complete List]
» 2 Member(s) | 10470 Guest(s)
