Not very happy with the photofinish
I wonder if at some point someone could come up with this process:
Put the foundation right on the wood/plywood used for the cabinet, that is guaranteed not to crack etc and that one could print/paint upon.
Then come up with some process to print right on this foundation on the plywood. Print any pattern you like, directly in colour.
Then you lacquer it and such.
RE: Not very happy with the photofinish - by morzh - 06-10-2014, 10:57 AM
RE: Not very happy with the photofinish - by sam - 12-18-2014, 12:23 AM
There are currently 3680 online users. [Complete List]
» 1 Member(s) | 3679 Guest(s)
