Not very happy with the photofinish
Being paper rather than plastic it would soak in the glue better, The reason I know it will work is that I used this process on my 37-84 but I printed it myself and the colour bled a little with my printer. A printing press could print the image alot sharper and larger.
RE: Not very happy with the photofinish - by tab10672 - 06-10-2014, 11:22 AM
RE: Not very happy with the photofinish - by sam - 12-18-2014, 12:23 AM
There are currently 10271 online users. [Complete List]
» 1 Member(s) | 10270 Guest(s)
