Dial Lamp Type for 42-380
Hello:
I'm looking to replace two dial scale lamps on a 42-380. The two that are dead are type 55. I'm not finding the correct dial lamp listing in the literature for the 42-380. The 55 is 7 volts.
Thanks for your help.
Dave
Dial Lamp Type for 42-380 - by Sourbone - 06-11-2014, 11:10 AM
RE: Dial Lamp Type for 42-380 - by Chuck Schwark - 06-11-2014, 02:36 PM
There are currently 9586 online users. [Complete List]
» 3 Member(s) | 9583 Guest(s)
