Stewart Warner alignment issues
Eric
I also suspect from the very end of your message #22 that you measured your capacitance and resistance while having resistor and cap in place; you can't do that. If you have a resistor and a cap that parallel each other you can only measure resistance, but not capacitance. Capacitor is always measured with one lead in the air.
Stewart Warner alignment issues - by Eric - 05-29-2014, 01:12 PM
RE: Stewart Warner alignment issues - by morzh - 05-29-2014, 01:25 PM
RE: Stewart Warner alignment issues - by Eric - 05-29-2014, 07:38 PM
RE: Stewart Warner alignment issues - by morzh - 05-29-2014, 07:55 PM
RE: Stewart Warner alignment issues - by Eric - 05-30-2014, 04:32 PM
RE: Stewart Warner alignment issues - by morzh - 05-30-2014, 07:06 PM
RE: Stewart Warner alignment issues - by Eric - 05-31-2014, 09:24 AM
RE: Stewart Warner alignment issues - by Eric - 06-01-2014, 09:15 AM
RE: Stewart Warner alignment issues - by morzh - 06-01-2014, 08:56 PM
RE: Stewart Warner alignment issues - by Eric - 06-02-2014, 03:14 PM
RE: Stewart Warner alignment issues - by morzh - 06-02-2014, 03:36 PM
RE: Stewart Warner alignment issues - by Eric - 06-02-2014, 04:07 PM
RE: Stewart Warner alignment issues - by morzh - 06-02-2014, 04:54 PM
RE: Stewart Warner alignment issues - by Eric - 06-02-2014, 05:04 PM
RE: Stewart Warner alignment issues - by morzh - 06-02-2014, 05:17 PM
RE: Stewart Warner alignment issues - by Eric - 06-02-2014, 05:24 PM
RE: Stewart Warner alignment issues - by Eric - 06-03-2014, 05:22 PM
RE: Stewart Warner alignment issues - by morzh - 06-03-2014, 05:25 PM
RE: Stewart Warner alignment issues - by Mondial - 06-03-2014, 06:30 PM
RE: Stewart Warner alignment issues - by Eric - 06-04-2014, 11:48 AM
RE: Stewart Warner alignment issues - by Eric - 06-11-2014, 03:12 PM
RE: Stewart Warner alignment issues - by morzh - 06-11-2014, 03:38 PM
RE: Stewart Warner alignment issues - by Mondial - 06-11-2014, 04:19 PM
RE: Stewart Warner alignment issues - by Eric - 06-11-2014, 05:15 PM
RE: Stewart Warner alignment issues - by morzh - 06-11-2014, 09:15 PM
RE: Stewart Warner alignment issues - by AI2V - 06-12-2014, 05:11 PM
RE: Stewart Warner alignment issues - by Eric - 06-14-2014, 07:34 PM
There are currently 3468 online users. [Complete List]
» 1 Member(s) | 3467 Guest(s)
