Philco 90 Audio Transformer
OK - I figured it out, I took apart my other G speaker and saw the connections. There is one tap that is just a tie point for the coil and the speaker cable. The other tap with the coil connection is the center tap.
Incidentally the 2848 audio transformer is identified in the Most Used Radio Diagrams for the Philco 96.
Philco 90 Audio Transformer - by nuke - 05-12-2014, 09:47 PM
RE: Philco 90 Audio Transformer - by morzh - 05-12-2014, 11:19 PM
RE: Philco 90 Audio Transformer - by nuke - 05-15-2014, 09:10 AM
RE: Philco 90 Audio Transformer - by morzh - 05-15-2014, 09:59 AM
RE: Philco 90 Audio Transformer - by Ron Ramirez - 05-15-2014, 10:35 AM
RE: Philco 90 Audio Transformer - by nuke - 05-15-2014, 11:08 AM
RE: Philco 90 Audio Transformer - by morzh - 05-15-2014, 12:13 PM
RE: Philco 90 Audio Transformer - by nuke - 06-08-2014, 07:31 PM
RE: Philco 90 Audio Transformer - by morzh - 06-08-2014, 08:07 PM
RE: Philco 90 Audio Transformer - by nuke - 06-08-2014, 09:21 PM
RE: Philco 90 Audio Transformer - by morzh - 06-08-2014, 10:07 PM
RE: Philco 90 Audio Transformer - by nuke - 06-11-2014, 10:38 PM
RE: Philco 90 Audio Transformer - by nuke - 07-01-2014, 10:15 PM
RE: Philco 90 Audio Transformer - by Arran - 07-01-2014, 11:02 PM
RE: Philco 90 Audio Transformer - by nuke - 07-01-2014, 11:05 PM
There are currently 6214 online users. [Complete List]
» 2 Member(s) | 6212 Guest(s)
