Will Philco 630 Speaker Fit Philco 620 Cabinet?
Here is the speaker bulletin that should list both models electrical spec's.
No physical dimensions are given though.
http://www.philcoradio.com/phorum/showth...hp?tid=215
Bill
It's not what you don't know that hurts you it's what you know that's not so.
Will Philco 630 Speaker Fit Philco 620 Cabinet? - by Guest - 08-19-2008, 04:00 PM
[No subject] - by wonderwrench - 08-19-2008, 05:42 PM
[No subject] - by Ron Ramirez - 08-19-2008, 05:44 PM
[No subject] - by Guest - 08-19-2008, 05:57 PM
There are currently 10425 online users. [Complete List]
» 1 Member(s) | 10424 Guest(s)
