Will Philco 630 Speaker Fit Philco 620 Cabinet?
Thanks to both of you! Thanks Ron. Your size info is what I needed! I really appreciate it.
Roger
Will Philco 630 Speaker Fit Philco 620 Cabinet? - by Guest - 08-19-2008, 04:00 PM
[No subject] - by wonderwrench - 08-19-2008, 05:42 PM
[No subject] - by Ron Ramirez - 08-19-2008, 05:44 PM
[No subject] - by Guest - 08-19-2008, 05:57 PM
There are currently 6291 online users. [Complete List]
» 4 Member(s) | 6287 Guest(s)
AvatarAvatarAvatarAvatar
