Philco 42-355, 395 dial cord diagram similar?
Thanks, Eric.
Philco 42-355, 395 dial cord diagram similar? - by don'tdomelikethat - 06-13-2014, 08:01 PM
RE: Philco 42-355, 395 dial cord diagram similar? - by don'tdomelikethat - 06-14-2014, 11:02 AM
There are currently 11435 online users. [Complete List]
» 2 Member(s) | 11433 Guest(s)
