What is this hole in my 40-201 cabinet?
This is all good, because I was planning to put a lit momentary switch there! For a moment I thought it may have been a keyhole for a locking mechanism for the lid, but I didn't see any way for that to work.
Thanks.
What is this hole in my 40-201 cabinet? - by Guest - 08-20-2008, 06:24 PM
[No subject] - by Terry Judkins - 08-20-2008, 07:59 PM
[No subject] - by Ron Ramirez - 08-20-2008, 09:36 PM
[No subject] - by Guest - 08-21-2008, 01:27 AM
[No subject] - by Texasrocker - 08-28-2008, 02:45 AM
[No subject] - by Guest - 08-28-2008, 01:50 PM
There are currently 7073 online users. [Complete List]
» 2 Member(s) | 7071 Guest(s)
