Philco D-10 needle source
Jim
There is a lot of difference. The D-10 uses a crystal cart. The D-10A uses a dynamic cart. The needle I have is for a D-10A. The D-10 uses a needle that is easy to find whereas a needle for the D-10A is hard to find.
The needle I have is in post #14 in the green package
Joe
Philco D-10 needle source - by brownie45 - 05-28-2014, 08:37 AM
RE: Philco D-10 needle source - by TA Forbes - 05-28-2014, 10:50 AM
RE: Philco D-10 needle source - by brownie45 - 05-28-2014, 12:48 PM
RE: Philco D-10 needle source - by sam - 05-28-2014, 01:18 PM
RE: Philco D-10 needle source - by Warren - 05-28-2014, 01:56 PM
RE: Philco D-10 needle source - by TA Forbes - 05-28-2014, 11:17 PM
RE: Philco D-10 needle source - by Ron Ramirez - 05-29-2014, 05:42 AM
RE: Philco D-10 needle source - by brownie45 - 05-29-2014, 06:58 AM
RE: Philco D-10 needle source - by Randy H. - 06-09-2014, 07:11 PM
RE: Philco D-10 needle source - by Ron Ramirez - 06-09-2014, 08:18 PM
RE: Philco D-10 needle source - by brownie45 - 06-09-2014, 09:39 PM
RE: Philco D-10 needle source - by Randy H. - 06-13-2014, 05:46 PM
RE: Philco D-10 needle source - by Ron Ramirez - 06-13-2014, 06:00 PM
RE: Philco D-10 needle source - by Skip - 06-13-2014, 06:11 PM
RE: Philco D-10 needle source - by Warren - 06-13-2014, 10:22 PM
RE: Philco D-10 needle source - by w4rtc - 06-14-2014, 07:53 AM
RE: Philco D-10 needle source - by brownie45 - 06-15-2014, 12:24 PM
RE: Philco D-10 needle source - by w4rtc - 06-15-2014, 05:01 PM
RE: Philco D-10 needle source - by brownie45 - 06-15-2014, 07:02 PM
RE: Philco D-10 needle source - by Warren - 06-15-2014, 08:29 PM
RE: Philco D-10 needle source - by w4rtc - 06-15-2014, 11:22 PM
RE: Philco D-10 needle source - by Warren - 06-16-2014, 01:53 AM
RE: Philco D-10 needle source - by w4rtc - 06-16-2014, 10:35 AM
The speaker table error?
Philco 70 antenna lead
