Philco 42-355 dial restringing help, please.
I figured it out. I was trying to reinstall the existing cord that came off of the shaft. Apparently you can't do it that way, so I just installed new string and routed it per the diagram.
Philco 42-355 dial restringing help, please. - by don'tdomelikethat - 06-16-2014, 02:32 PM
RE: Philco 42-355 dial restringing help, please. - by don'tdomelikethat - 06-17-2014, 09:56 AM
There are currently 10841 online users. [Complete List]
» 1 Member(s) | 10840 Guest(s)
