Magnavox saved from the dump.
You can roll your own FM multiplex adapter using an IC, a perfboard, and some resistors and capacitors. Instructions are easy to find on the web, just Google "FM multiplex adapter" and it will return several hits.
Magnavox saved from the dump. - by Jayce - 06-17-2014, 11:10 AM
RE: Magnavox saved from the dump. - by morzh - 06-17-2014, 11:22 AM
RE: Magnavox saved from the dump. - by Jayce - 06-17-2014, 02:24 PM
RE: Magnavox saved from the dump. - by Ron Ramirez - 06-17-2014, 03:52 PM
RE: Magnavox saved from the dump. - by Jayce - 06-17-2014, 10:05 PM
RE: Magnavox saved from the dump. - by Arran - 06-18-2014, 10:39 PM
RE: Magnavox saved from the dump. - by Jayce - 06-18-2014, 10:44 PM
RE: Magnavox saved from the dump. - by Arran - 06-20-2014, 09:58 PM
RE: Magnavox saved from the dump. - by Jayce - 06-24-2014, 11:36 AM
Eico 232 VTVM Schematic
