Model 70
I fell into a good deal today and acquired a Philco Model 70 and need some expertise. All the 70 models that I see are pretty much a cathedral style, but this piece that I acquired is not. The electronics in this cabinet are a Philco Model 70. The cabinet however does not look like anything I have been able to find on the web. My question to you Philco experts, is this an original style cabinet? Is it even a Philco style cabinet? I am under the impression that the electronics were somewhere along the line transferred into this cabinet.
Here are some pictures of this deal that I got.
http://www.geocities.com/konen3/frontview.jpg
http://www.geocities.com/konen3/rear.jpg
Any help would be greatly appreciated.
Model 70 - by Guest - 08-23-2008, 11:57 PM
[No subject] - by Ron Ramirez - 08-24-2008, 07:56 AM
[No subject] - by DeckApe - 08-24-2008, 10:17 AM
There are currently 10184 online users. [Complete List]
» 1 Member(s) | 10183 Guest(s)
