46-1209 tone issues
Bad solder.
Bad tone potentiometer.
46-1209 tone issues - by philco4me - 06-18-2014, 01:59 PM
RE: 46-1209 tone issues - by morzh - 06-18-2014, 03:31 PM
RE: 46-1209 tone issues - by philco4me - 06-18-2014, 04:50 PM
RE: 46-1209 tone issues - by morzh - 06-18-2014, 04:58 PM
RE: 46-1209 tone issues - by philco4me - 06-18-2014, 05:35 PM
RE: 46-1209 tone issues - by TA Forbes - 06-20-2014, 09:49 AM
There are currently 10353 online users. [Complete List]
» 1 Member(s) | 10352 Guest(s)
