Philco 80 missing part
Interesting.
Without this cap the Grid Leak detector should simply not work.
The radio could use some parasitics and still detect, but not via grid leak.
Unless they had some non-obvious cap there.
Philco 80 missing part - by llhat - 06-18-2014, 01:54 PM
RE: Philco 80 missing part - by Ron Ramirez - 06-18-2014, 04:20 PM
RE: Philco 80 missing part - by morzh - 06-18-2014, 04:27 PM
RE: Philco 80 missing part - by morzh - 06-18-2014, 04:29 PM
RE: Philco 80 missing part - by Ron Ramirez - 06-18-2014, 04:32 PM
RE: Philco 80 missing part - by llhat - 06-19-2014, 11:52 AM
RE: Philco 80 missing part - by Randy H. - 06-19-2014, 02:58 PM
RE: Philco 80 missing part - by morzh - 06-19-2014, 03:16 PM
RE: Philco 80 missing part - by markmokris - 05-05-2015, 08:37 AM
RE: Philco 80 missing part - by Ron Ramirez - 05-05-2015, 08:46 AM
RE: Philco 80 missing part - by markmokris - 05-05-2015, 09:18 AM
RE: Philco 80 missing part - by Ron Ramirez - 05-05-2015, 09:36 AM
There are currently 5897 online users. [Complete List]
» 1 Member(s) | 5896 Guest(s)
