new safety caps from Justradios
Morzh:
Another reason I like the Nichicon CS series.. they have a really high ripple current along with their super long life. they are generally reasonably priced.
new safety caps from Justradios - by bfrohwein - 06-17-2014, 03:07 PM
RE: new safety caps from Justradios - by Warren - 06-17-2014, 03:12 PM
RE: new safety caps from Justradios - by morzh - 06-17-2014, 07:12 PM
RE: new safety caps from Justradios - by Arran - 06-17-2014, 09:41 PM
RE: new safety caps from Justradios - by morzh - 06-18-2014, 10:06 AM
RE: new safety caps from Justradios - by David - 06-18-2014, 06:21 PM
RE: new safety caps from Justradios - by morzh - 06-18-2014, 07:31 PM
RE: new safety caps from Justradios - by bfrohwein - 06-18-2014, 08:11 PM
RE: new safety caps from Justradios - by David - 06-18-2014, 08:15 PM
RE: new safety caps from Justradios - by morzh - 06-18-2014, 09:06 PM
RE: new safety caps from Justradios - by Arran - 06-18-2014, 09:32 PM
RE: new safety caps from Justradios - by morzh - 06-18-2014, 10:04 PM
RE: new safety caps from Justradios - by Arran - 06-19-2014, 02:33 AM
RE: new safety caps from Justradios - by David - 06-19-2014, 05:52 PM
