  • 1 Vote(s) - 5 Average
111 grillcloth cardboard frame.
#41
Glued together after cutting the groove.
The old cardboard glued to pad the cloth
Glued to the frame.
111 grillcloth cardboard frame. - by morzh - 05-11-2014, 09:12 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 01:35 AM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 10:15 AM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 11:01 AM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 12:11 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 02:50 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 03:10 PM
RE: 111 grillcloth cardboard frame. - by codefox1 - 05-12-2014, 03:23 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 04:21 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 05:06 PM
RE: 111 grillcloth cardboard frame. - by Jamie - 05-12-2014, 05:19 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 11:23 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 11:37 PM
RE: 111 grillcloth cardboard frame. - by sam - 05-13-2014, 12:49 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-13-2014, 03:02 PM
RE: 111 grillcloth cardboard frame. - by Jamie - 05-13-2014, 07:07 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-13-2014, 08:20 PM
RE: 111 grillcloth cardboard frame. - by Joeztech - 06-01-2014, 09:48 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-01-2014, 09:52 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-02-2014, 02:09 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-02-2014, 03:33 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-02-2014, 03:47 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-02-2014, 11:22 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-03-2014, 08:56 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-07-2014, 08:34 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-07-2014, 10:36 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-08-2014, 12:17 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-08-2014, 12:38 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-18-2014, 10:37 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-18-2014, 09:00 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-18-2014, 09:09 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-18-2014, 11:14 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-19-2014, 07:27 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-19-2014, 09:37 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-19-2014, 03:18 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-19-2014, 05:36 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-20-2014, 11:49 AM
