Magnavox saved from the dump.
That's because the system is already designed to have the multiplex added at a later date. This is even mentioned in the instruction manual that the multiplex would soon be available for purchase to install.
Magnavox saved from the dump. - by Jayce - 06-17-2014, 11:10 AM
RE: Magnavox saved from the dump. - by morzh - 06-17-2014, 11:22 AM
RE: Magnavox saved from the dump. - by Jayce - 06-17-2014, 02:24 PM
RE: Magnavox saved from the dump. - by Jayce - 06-17-2014, 10:05 PM
RE: Magnavox saved from the dump. - by Arran - 06-18-2014, 10:39 PM
RE: Magnavox saved from the dump. - by Jayce - 06-18-2014, 10:44 PM
RE: Magnavox saved from the dump. - by Arran - 06-20-2014, 09:58 PM
RE: Magnavox saved from the dump. - by Jayce - 06-24-2014, 11:36 AM
