Silvertone 1154 grandmother clock radio
Should the power xfrmr be bad I may have one here that will work.
RE: Silvertone 1154 grandmother clock radio - by TA Forbes - 06-20-2014, 10:12 PM
There are currently 4280 online users. [Complete List]
» 3 Member(s) | 4277 Guest(s)
