Silvertone 1154 grandmother clock radio
The control panel looks like Australian walnut. Honestly I have to wonder about some people, I would never have put a cheap battery powered clock in there even if there was something wrong with the original. If I had to make it work I would adapt the mechanism from a newer electric clock, the kind Telechron used to make, at least it would look better and keep good time.
RE: Silvertone 1154 grandmother clock radio - by Arran - 06-20-2014, 10:32 PM
There are currently 4520 online users. [Complete List]
» 2 Member(s) | 4518 Guest(s)
