Silvertone 1154 grandmother clock radio
Yeah the clock face which appears original (from photos of others and the fact that there are 4 empty mounting holes) says Hammond on it. Plus the radiomuseum site quotes an old ad that says "Hammond electric clock movement". I'm sure I'll find one sooner or later. I'm patient and persistent.
The one photo I could find of the rear, which seems original, showed the movement with 2 knobs over a data plate. One knob larger than the other and the movement was enclosed in a round case. I've seen at least one so far on ebay that looks identical physically. I searched for 1931 Hammond electric clock.
RE: Silvertone 1154 grandmother clock radio - by Groundhog74 - 06-22-2014, 09:16 AM
There are currently 5952 online users. [Complete List]
» 1 Member(s) | 5951 Guest(s)
